Plz help me, i have aficio 1013 copier when I ON power switch its giving only beepig sound and sever switch LED light shows green but nothing display.again and again main power switch off and on it become OK.
SOURCE: ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
SOURCE: Aficio Copier 1013 light on to load paper ( paper is loaded)
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic
SOURCE: I have a Nashua sc550
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
