I am trying to install .Net Framework 3.5 in Server 2012 but I am getting an error 0x800F081F that installation of one or more roles, role services or features failed. The source file could not be found. How can I resolve this? I need to set up Sage Premium that is demanding a .Net framework 3.5 as one of its prerequisites.
Hope this will help you.. :)
How to troubleshoot error 0x800F081F when installing roles and features...
Hello
This error code 0x800F0906 issue can appear during window installation.You can fix this error code 0x800F0906 by Media creation tool.
https://www.errorsdoc.com/windows/fix-net-framework-3-5-error-code-0x800f081f-in-windows-10/
SOURCE: .Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
SOURCE: error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
Thank you very much for your answers all of you. The problem has been resolved. All I did was to remove all the updates that the Server download automatically. I should believe that there was an update that was blocking the installation of Dot Net Framework itself. Once that was done,I managed to add the feature (Dot Net Framework 3.5) through server roles, without any errors.
Thanks
Daniel
