SOURCE: Saeco Italia SUP021 YR - Red light #29 on solid
Comment on oily beans - try not to use them. If you are looking for a stronger flavor coffee, an an extra shot to your drink. Oily beans cake inside the grinder, brew group + components and strains them potentiallu causing malfunctions.
Also dark beans are usually over roasted which makes the makes real coffee flavor lose. Espresso coffee beans should have very little to no oil and be unifrom in color.
Another approach if you are looking for stronger coffee flavor. use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee. Visit http://www.coffeetico.com/did_you_know.htm for some more interesting information.
SOURCE: Saeco Italia water lite and green lights flashing
Try to open the steam knob and make a cup of water (tea), see if you can get a full cup or just a half.
How old are your machine?
How often do you descale the machine?
Best regards
/Mirran
SOURCE: Saeco Italia won't turn on.
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
try this website
SOURCE: Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
