Question about Canon Pixma MX922
Vertical lines/letters print in a wavy form, Black ink, not Colors and not images, like jpg files
I have changed both black print tanks; run alignment maintenance functions; cleaned the print heads. Is it fixable?
6ya staff
SOURCE:
valleylee
SOURCE: Black 3ek cartridge not printing
I had the same problem before with 3e black ink. It simply does not print too, so what I did if i get to print black and white i will set the characters into dark gray! it looks like draft printing but the things is it can be printed.. I tried to do every instructions available but to fail. I almost dump it till I decided to set it aside for a while. After a week I tried using it again, and it functions well. I guess the printer just want to say, "HEY BUDDY, GIVE ME A LITTLE BREAK!"
Posted on May 15, 2008
Anonymous
  • 49 Answers
SOURCE: Faulty Ink Cartridge?
You can try this, but maybe a new print head is needed.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
Anonymous
SOURCE: Vertical black line running length of the paper
I have a PIXMA iP5200 with the vertical black ink smear problem down the back of the paper. I called the local Canon printer repair facility, and a serviceman said that the black line is caused by too much ink in the ink absorber device below the paper path. He said to fix it would cost $60 to $90 because it requires disassembling part of the printer, replacing the absorber foam, installing a longer tip for the excess ink, and reassembling and testing the printer. I asked if this would be a permanent fix. He said no, that the problem could reoccur.
Given the cost of repair and the age of the printer (over 3 years), I decided today to buy a Canon MX850 All-in-One printer at the local Staples, which cost me $169 after a $30 mail-in rebate from Canon. The MX850 uses the same printer cartridges as the iP5200 and offers lots more features
Except for the recent printing problem, I got excellent results and service from the iP5200 over the time I used it.
Jim
Portland, OR
Posted on Oct 22, 2008
Anonymous
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
Anonymous
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
Printing a table the vertical lines shift left/right about the width of the line as the head moves back & forth. This only occurs with the black cartridge in use, not the color cartridge. The black...
sounds like you replaced the black cartridge, do you run the "align print head" on the printer. Sounds like the black is not aligned to the printer input.
Jan 10, 2018 | Hummingbird CannonLink Ink Feed System
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
My copy prints come out blurry after changing ink cartiges
Try this:
Checking the print quality:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
  4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
  5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
  6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
    If you can see missing short lines, press 2 (NO) and go to Step 7.
  7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
  8. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
  9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
  10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
Setting the Alignment:
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
    If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
    Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Canon Pixma MX922 Logo
867 people viewed this question
Clive
Clive
old marine
old marine
Ekse
