All of a sudden chair stopped working. It now peeps and kicks out the 3 red, 4 yellow, 1 green error. I'd like to fix myself any ideas what the problem is. Thanks much.
Check connections to controller, may have damage.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Its sounds like a bad connection problem,make sure all connections are good and tight.Check this web site for more help http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Good luck
