SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
SOURCE: Neff s4459n2 dishwasher not draining
It is so common that the drain does not work in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has not drained then the drain hose pump/valve and fittings which are located on the underside of the machine must be checked. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve,, check the voltage on the drain pump during the cycle . If no voltage is present the program controller can be faulty.
