LG 42PX5D 42 in. Plasma HDTV Logo
D
DEBBIE SMITH Posted on Jan 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY TV KEEPS HAVING VERTICAL LINES OF DIFFERENT COLORS IF YOU TURN IT OFF AND BACK ON IT CLEARS UP BUT IT IS DOING IT MORE FREQUENTLY.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Jan 14, 2016
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987209
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
My Vizio TV has a bar of colored lines running veritcally over the picture. Should I replace the T-Con board?
What causes vertical colored lines on a TV screen? When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
https://removeandreplace.com/2018/05/01/tv-has-different-color-vertical-lines-on-screen-how-to-fix/
Hi there I have a TV Samsung 46 inch model LN46B640R3FXZA It has vertical lines intermittently (more often than not) that slowly show up in different parts of the screen. Thank you Stami
Try cooking the tcon board in the oven...there are some postings on youtube that tell how to do it, if that doesn't help replace the board...Good luck!!
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
2answers
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
How may I fix colorful vertical lines on screen but clear voice on Sharp Aquos TV when I first turn it on?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
When i turn my vizio on is all it does is display vertical lines from top to bottom
mychaelmuch6
Go to menu.
press screen selection
just follow steps on how to clear or reset T.V.
22helpful
5answers
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
