Model Samsung UN50jU7100F
Amazon.com: Customer Discussions: battery installation for remote ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jun 11, 2014 - As strange as it may seem to everyone else I cannot figure out how toopen the remote for my Kindle HD TV to put the batteries in.
Amazon Fire TV Stick: How To Open The Remote's Battery ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE
Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: ... Amazon Fire TV Stick: How To Open TheRemote's Battery Door.
Open Amazon Fire TV 2015 remote battery compartment ...
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M
Oct 6, 2015 - Uploaded by sfsilicon
I am not responsible for any damage to your remote. Proceed with caution. This video shows you how to open ...
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
