Yes. I am familiar with these.
You or someone will be needing to take a large bucket or some pans and put them under the sink and undo all the pipes and the drains and the garbage disposal.
You will find a plugged up pipe.
I have already unplugged my daughter's about 10 times in the last 10 years.
Usually, the problem is she has put something down the sink she shouldn't have.
Example: Egg shells. Will not wash down. Rough silage: Clogs pipes.
When you get it apart, you will likely identify the product causing the problem.
God bless your efforts.
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
The whirring sounds like the motor is running under no load conditions. Whatever has it clogged apparently hasn't gotten down to the motor yet. I know you are trying to avoid removing it but you may have to to unclog it. Some types have a valve that is solenoid operated between the sink and the grinder motor. If yours is so equipped then it will have two wires right under where it comes out of the sink. If so then this solenoid could be malfunctioning and not letting the garbage get to the grinder. If not, I would suggest you remove it and check it to see what has it clogged. That's about all I know to tell you to try. Sounds like the unit is working it's not receiving the garbage. If I can be of any further assistance please feel free to contact me.
Col. Dana Gillespie
I have seen where some houses are built with long runs of plumbing under the kitchen floor where the angle isn't the best and a garbage disposal installed under that situation is not good. Check to see how your plumbing is. Is it a fast run down near the kitchen or a long run sideways?
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain.
Sounds like a clog that was there prior to you putting the lemon in the GD.
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up.
__________________
