Blue Screen Comes and Computer (Dell 1525) Keeps Restarting HELP!
When I turn on my computer it loads fine until it gets to the green bar then the blue screen will turn up but it flash then restart again. Can anyone help on this real fustrating problem. thax
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Hi. All Dell Notebooks has this Image Restore in one of the partitions of the hard drive.
You may restore factory settings of your computer but your files will be lost.
Try to boot using safemode with networking first so you can save your files online.
Turn your computer on and on the Dell logo, press Ctrl+F11 if system came with pre-loaded XP then follow the intructions.
If system came with windows Vista, on Dell logo, press F8 and select Repair your computer and press Enter. Click Next and/or enter your password if asked. If not, follow the intructions until your system goes back to factory image.
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
If the computer is restarting continously at the windows loading screen then you have a windows issue of which your computer is "Blue Screening" and restarting. In this case you arent really seeing the blue screen as windows restarts immediately as the error occurs. My advice to you is to press F8 before the windows loading screen and choose to "not restart automatically on error" that is not entirely what it says but its to that regard. If that doesnt work try pressing the "Pause Break button continously until the blue screen appears, read the error and google it to find out what is causing the error and go from there. Please feel free to get back to me on this if my information doesnt help or i need to explain further.
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
don't hit ctrl, f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive (usually the D: drive) good luck.
Not sure what the problem is, but I would suggest pressing the Fn+F5? There is a function key that toggles from dual screen, just the laptop screen or just the monitor. Hope that helps..
