Brizo Kitchen Spout Logo
Dan Gifford Posted on Jan 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No water out of touchless faucet - Brizo Kitchen Spout
L Pfaff
Level 3:
Top Expert:
  • Master 11,573 Answers
  • Posted on Jan 11, 2016
L Pfaff
Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3584134
Points
181713
Check batteries and replace and reset. Link below may help if batteries are found to be OK
press helpful button
http://www.brizo.com/customerservice/contact.html#.VpMqj7YrJxA
Why does touchless water faucet only work when other faucet turned on?
It's possible that the solenoid valve in the touchless faucet is not functioning properly, and needs to be replaced. Another possibility is that there is a loose or broken wire in the electrical circuit that powers the solenoid valve. You may want to check the connections and wiring, and consult a plumber or electrician if necessary, to help diagnose and repair the issue.
Oct 18, 2021 • Plumbing
Delta touchless faucet turns on just fine, but there is a several seconds delay when I turn it off. I did replace the batteries
Open the battery case and realign the batteries with the positive and negative poles in the right positions according to the layout in the battery compartment. Close the battery compartment. Make sure it locks completely before continuing.
Locate the reset button, if any, on or near the battery compartment, after changing out batteries.
Push the red reset button to reset the faucet.
Test the faucet to ensure the reset corrected the problem.
Tip
Not all automatic faucets have red reset buttons. Some faucets just require inserting new batteries or realigning the batteries in the compartment to complete a reset. on the faucet. Check the instructions that came with your automatic faucet or locate the user's guide online at the manufacturer's website.
1helpful
What is the best kitchen faucets?
There is an many kind of kitchen faucets in the market. Most of the famous brands have made high quality durable faucets. Some faucets are pull out some are pull down types. In current market analyses showing us some peoples are moving to touchless kitchen faucets,because of the easy of use and water saving ability of it.
Jun 06, 2018 • Plumbing
What is the difference between touch and touchless faucets?
"Touch" faucets require you to make physical contact with the metal body to activate the water flow. "Touchless" units have an infrared sensor that "feels" your body heat when you wave your hand under the faucet.
Apr 10, 2018 • Plumbing
3answers
How can choose a touchless kitchen faucet?
The market is full of brands making these faucets but how to decide which one is the best suited to your needs. Below mentioned are few things which should be kept in mind while making a purchase of a touchless kitchen faucets.
  • Position of the motion sensor
    It is important to check where the sensor is placed on your kitchen faucet. Their position varies from brand to brand. Some of them come with the sensor installed on their spout, while others have them at the bottom or the top of the faucet. It is up to you to select the one which suits your needs. Moen touchless faucets have two sensors, and the wave sensor is placed at the top which is responsible for the activation and deactivation of water flow and the other sensor, ready sensor is placed at the bottom, which is used merely for identifying the articles in your sink.
  • Power Source
    When it comes to a power source, there are two types of touchless kitchen faucets in the market. For the ones that need a continuous power supply you have to make sure that they are installed near a power outlet in your kitchen. The other type runs on a battery and can be placed anywhere. You can choose either depending upon your kitchen needs.
  • Others
    Before buying the faucet for your kitchen make sure its length, height, etc. is appropriate for your kitchen. Also make sure whether it is easily installable or not.
Mar 19, 2018 • Plumbing
Touchless kitchen faucet back sensor does not work
is there something wrong with your car or truck?
How do i replace cartridge in a kohler sensate faucet
Follow the directions that came with the faucet. If you do not have them, go to the manufacturers website and download them.
Touchless soap dispenser will not stop
wipe the sensor or the entire machine with water
I want a faucet that shuts itself off (saves h2o).
search for "touch faucet" (Delta and Kohler have a few) or search for touchless faucets (many manufacturers have these with a sensor like at public restrooms)
May 07, 2010 • Home
Top Brizo Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Brizo Home Expert? Answer questions, earn points and help others
