Only one key on my Targus wireless keyboard won't work. Any way I can clean or remove the key to get it to work
SOURCE: targus wireless keyboard is not working on my dell axim x30 pocket pc
DEAR MARVYMAR, AS YOU TOLD ME THAT YOU HAVE DONE ALL THESE AND STILL YOUR KEYBOARD DOES NOT WORK THE CHECK YOUR KEYBOARD I THINK YOU KEYBOARD HAS SOME MFG.FAULT DO ONE THING CHECK ANOTHER KEYBOARD ON YOUR PC IF YOU FACE SAME PROBLAM THEN SOME SETTING FAULT ON YOUR PC THEN TELL ME AGAIN. BYE
SOURCE: is not compatable with psp
I just did a Google search. If you have a Quake, it will work. All other models will only work with Palms or Pocket PCs.
SOURCE: Keys do not work intermittently. Need to remove & clean.
Most travelmates have a couple of clips holding the keyboard in place, if you look at the top of the keyboard there is usually 4 clips that you can gently push back with a screwdriver. Just be carefull of the ribbon cable attached to the keyboard, don't yank it out.
SOURCE: old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
SOURCE: Following keys not working on MS wireless 1000
Have you downloaded the proper keyboard setup application from Microsoft's site? It is at http://www.microsoft.com/hardware and you will find the software for their keyboards and mice there.
Look for "Intellitype Pro" with numerics which specify the version and/or date.
You should have gotten this on a CD with the keyboard.
Good Luck,
-a.
