GE JS900 electric range. The top burners work fine. There are no lights or clock on control panel so the oven cannot be turned on. This was realized after not using the oven for a week or so.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
SOURCE: No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
