The ice will not come though the door i do not hear the motor ruining, the water will come out.
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: I have a Kenmore side
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
I don't know how to get the front cover off
Of the ice and water dispensor
