Question about Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB
Print unable 0A, what is solution? - Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB
    Sergeant:
  • 164 Answers
Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on. - If no error message appears on your machine's
Posted on Apr 20, 2019
Anonymous
SOURCE:
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
WARRANTY AND SERVICE OPTIONS.
Brother Authorized Service Center locator
Jan 12, 2018 | Office Equipment & Supplies
This usually a mechanical problem in the printer if shutdown or restart doesn't work you need to take contact brother
Print Unable or Print Unable XX Brother
Feb 26, 2016 | Brother Office Equipment & Supplies
How to program a RC 401 0A remote control
Check this video.
http://www.google.co.in/url?sa=t&rct=j&q=RC+401+0A+remote+control&source=web&cd=1&ved=0CDAQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D36RHf-TcKNo&ei=IzEZUfbeLc3jrAex9YCwCQ&usg=AFQjCNGvPj_30Yup5-D0yCwEI9PaIvdA7Q
Feb 11, 2013 | Dynex RC-401-0A
Have a Toshiba 500GB external hard drive, model: HDDR500E03X and I've been using it for some time on a few of my computers, but lately it hasnt been displaying. I dont know much about Ubuntu to begin...
Sounds like some kind of bad wire, you hope. It could be a power issue as you have stated, I would try it out on several diffrent computers, and you were not wrong in trying the y cable. But if that still doesnt work then not all is lost. I would recomend opening up the caseing and removing the hard drive. Even external drives simply use standard laptop SATA drives. If you have a desktop you can simply plug in the drive while your computer is off, if you do not have xtra spots to plug it up you could temp unpulg your dvd drive to test it. If you have a laptop than you can buy several devices to use a sata drive though usb. http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071&cm_re=usb_sata_docking_station-_-17-153-071-_-Product
This is the one I use the most.
Good luck , if you have any questions let me know
Prodigz2
Mar 12, 2011 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
What is the value of 0*0A? How????
It appears to be an Hexadecimal number and the value is 10.
Hex Dec
01 = 1
05 = 5
09 = 9
0A = 10
0B = 11
0C = 12
0D = 13
0E = 14
0F = 15
10 = 16
11 = 17
Nov 25, 2010 | Computers & Internet
Can emc ax150 work without the UPS cable?
I moved my AX-150 to a location that would not allow me to install the UPS as it has redundant power/UPS and you should not connect a UPS to the output of another UPS.
Without the UPS the AX-150 forces the Write Cache to be Disabled. Performance drops, form what I have tested, to around 25x slower. This is due to not just turning off the controllers write cache, but as with ALL RAID controllers, the onboard drive 8/16M write cache is disabled as well so the drives are even slower then they would be if they where not used on a RAID controller.
The write cache disable is your real killer! Actually the write cache is disabled one a week while the REQUIRED battery test is performed.
My solution was to write an APC SmartUPS Serial Emulator that talks to the AX-150 telling it that the UPS is working fine so the write cache never gets turned off, including during the weekly battery test!
Here is the needed RJ45 to DB9F. Colors are base on someone cutting off the end of a cat5 patch cable.
You can find the APC SmartUPS commands off the web.
Communications capture:
Normal Comms from/to AX-150
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
!!! Weekly Batt Test Time !!!!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
W >> !! Tests battery, like pushing the test button on the front panel
OK<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
X >> !! Self-test results
OK<0D><0A>
l >> !! Low transfer voltage
097<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
n >> !! Get Serial number
AS0632112344<00><0D><0A>
R >>
BYE<0D><0A>
!!! End of Test !!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
I would be happy to share the Delphi source and EXE with anyone that would like to use it. Do not see a place to attach files here.
Can give you snapshot of main command-response logic:
if Result = pmerGood then
begin
tRx := Engine.RxString;
if cbHex.Checked then
Msg(Engine.SeeBytes(tRx)+ ' >> ' + #$0D + #$0A)
else
Msg(Engine.SeeChars(tRx)+ ' >> ' + #$0D + #$0A);
PendingCmd := '';
Engine.CharDelay := 0;
CmdData := 'NA' + #$0D + #$0A;
if length(tRx) > 0 then
case ord(tRx[1]) of
$01 : CmdData := 'Smart-UPS 750 RM' + #$0D + #$0A;
$1A : CmdData := '#uD43127130133136uA43108110112114uI43253257261265uM432252292' + '33237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF' + #$0D + #$0A;
ord('A') : CmdData := 'OK' + #$0D + #$0A;
ord('B') : CmdData := '27.40' + #$0D + #$0A;
ord('C') : CmdData := '016.2' + #$0D + #$0A;
ord('D') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('E') : CmdData := '336' + #$0D + #$0A;
ord('F') : CmdData := '60.00' + #$0D + #$0A;
ord('G') : CmdData := 'S' + #$0D + #$0A;
ord('I') : CmdData := 'FF' + #$0D + #$0A;
ord('J') : CmdData := '0F,00' + #$0D + #$0A;
ord('K') : CmdData := 'OK' + #$0D + #$0A;
ord('L') : CmdData := '126.7' + #$0D + #$0A;
ord('M') : CmdData := '128.1' + #$0D + #$0A;
ord('N') : CmdData := '125.2' + #$0D + #$0A;
ord('O') : CmdData := '113.0' + #$0D + #$0A;
ord('P') : CmdData := '000.0' + #$0D + #$0A;
ord('Q') : CmdData := '08' + #$0D + #$0A;
ord('R') : CmdData := 'BYE' + #$0D + #$0A;
ord('S') : CmdData := 'OK' + #$0D + #$0A;
ord('U') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('V') : CmdData := 'FWD' + #$0D + #$0A;
ord('W') : CmdData := 'OK' + #$0D + #$0A;
ord('X') : CmdData := 'OK' + #$0D + #$0A;
ord('Y') : CmdData := 'SM' + #$0D + #$0A;
ord('a') : CmdData := '3.!$%+?=#|.' + #$01 + #$0E + #$1A + ''')+-89>@ABCDEFGKLMNOPQRSUVWXYZabcefgjklmnopqrsuxyz~' + #$0D + #$0A;
ord('b') : CmdData := '615.3.D' + #$0D + #$0A;
ord('c') : CmdData := 'UPS_IDEN' + #$0D + #$0A;
ord('e') : CmdData := '00' + #$0D + #$0A;
ord('g') : CmdData := '024' + #$0D + #$0A;
ord('f') : CmdData := '100.0' + #$0D + #$0A;
ord('i') : CmdData := 'FWD' + #$0D + #$0A;
ord('j') : CmdData := '0375:' + #$0D + #$0A;
ord('k') : CmdData := '0' + #$0D + #$0A;
ord('l') : CmdData := '097' + #$0D + #$0A;
ord('m') : CmdData := '08/03/06' + #$0D + #$0A;
ord('n') : CmdData := 'AS0632112344' + #$00 + #$0D + #$0A;
ord('o') : CmdData := '120' + #$0D + #$0A;
ord('p') : CmdData := '090' + #$0D + #$0A;
ord('q') : CmdData := '02' + #$0D + #$0A;
ord('r') : CmdData := '000' + #$0D + #$0A;
ord('s') : CmdData := 'H' + #$0D + #$0A;
ord('u') : CmdData := '127' + #$0D + #$0A;
ord('x') : CmdData := '01/01/10' + #$0D + #$0A;
ord('y') : CmdData := '(C) APCC' + #$0D + #$0A;
ord('z') : CmdData := 'CLEAR' + #$0D + #$0A;
ord('9') : CmdData := 'FF' + #$0D + #$0A;
end;
if CmdData <> '' then
begin
Msg(Engine.SeeBytes(CmdData)+ #$0D + #$0A)
else
Msg(Engine.SeeChars(CmdData)+ #$0D + #$0A);
Engine.SendMsg := CmdData;
end;
Bob A. Hay
Mar 02, 2010 | EMC 1U UPS 120V FOR AX150 (AX150UPS120V)...
This the messagethat got Content-Type: text/plain; charset=iso-8859-1 Content-Transfer-Encoding: quoted-printable I'm trying=A0 to connect with you for a very long time, why don't you call = me or...
That is and HTML message that may not have been assembled correctly by the sender or corrupted during transmission and reception. That is not rare.
Nov 06, 2009 | Yahoo Mail
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
PH SIG ERR: 39:02:
phone sig error mean your Phone MonsterPack(software) is demaged. you need to flash back using RSD lite to make back to normal. give me what software version you have on your cell and what bootloader you have..eg.bootloader 0A.30/0A.52..SW:R479 and etc. i these so i can upload one for you
Jan 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB Logo
2,041 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
