Navigon 5100 When connected to charger, computer icon comes up
Anytime I connect my Navigon 5100 to the charger, the computer connected icon comes up, and I cannot use the GPS. Thus, I am limited to only using battery power, which only lasts a few short hours.
Wiring diagram pinout for Navigon GPS charge and concurrent use
Pin
Pin Name
Description
+5V
5 Volts Direct Current
Data
floating/Not connected
Data
X
Ident
Conneted to Pin 4 (GND) as pure short, no resistor
Ground
Ground, shorted to pin "X"
Use of standard mini-b will place unit in
Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short
will allow use of Navigation software and concurrent charging. USB power
source must be 1000 ma or above.
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Hello 1234567i, Most GPS receivers are not designed to be used for tracking. The GPS receives signals from Global Positioning Satellites and then uses those signals to calculate its current location, which it displays on the screen. However that data is not normally sent anywhere externally so there is no way for a remote user to determine where the GPS is.. Thus you cannot use a computer or any other device to track the GPS. The Navigon 5100 appears to be no exception. Without pairing the GPS with an external communications device (cell phone, two-way radio, laptop with a WiFi connection, etc.) the GPS lacks the ability to transmit its location reports to any external source. There certainly are ways that a GPS can be used with an external communications device as a tracker, but most GPS receivers do not have this capability out of the box. Best Regards, Ken "Go Ahead. Use Us."
