SOURCE: Pressure washer intermittent turn on
sounds like a pressure switch is sticking. usually causes this problem especially after being stood for a while not used.
have to remove cover to get to pressure switch, remove pressure switch piston clean regrease with silicon grease refit it m and all should be good.
SOURCE: switch clicking on start up wont start lights flash at same time
tried the battery, charge it manually, sounds silly but i had this problem with my 600ss
thanks
SOURCE: 2006 colorado intermittently fails to start. It
Clean all the electrical connections you can get to under the hood with automotive electronics cleaner,dry with compressed air and pack each connector with di-electric grease.
SOURCE: Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
My experience is working over 10 years at Pasquini as a master technician
running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso
machines and grinders. Contact us for any of your Pasquini sales and
service needs.
SOURCE: grundfos mq3-45 pressure booster pump
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
