Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
B
Binay Prakash Posted on Jan 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model SMH 18165. How do I replace handle? - Samsung 1.8 Cu. Ft. Over-the-Range Microwave
William Miller
Level 3:
  • Samsung Master 9,179 Answers
  • Posted on May 23, 2016
William Miller
Samsung Master
Level 3:
Answers
9179
Questions
Helped
4478229
Points
21747
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Model SMH 18165. How do I replace handle? - 26043454-2eaufixstlx223aid0wpxsf5-4-0.jpg
Where can I get the Maintenance manual for Samsung model SMH 9187 ST
It's for sale for $12 in electronic format at samsungparts.com.
I just bought at Lowes a marked down Samsung over the stove microwave but it didn't have a manual or installation instructions. The model # is: SMH 1926S. Can you help me? Especially with installation
Did you get the wall mount bracket? If not. it will never mount up. Go to the Samsung website. You should be able to get operating and mounting instructions there.
Handle broken
I need to replace handle which fell off. Whenre do I find handle> Do not have model #
I have a samsung microwave oven,model smh 7185,does it have an internal fuse?
Most MW do have an internal fuse, most likly a 10 amp ceramic (HRC) You can replace with a glass one but if it blows it could rupture
Broken handle on whirlpool model MH7140XF. how do I remove the face of the door with out breaking it?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is available at appliancepartspros.com. There are several part numbers listed, based on the color of your oven, so make sure you order the correct handle. Here is the parts listing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=93877#d93877
If you have any questions, please post back and let me know. I hope this helps you
I purchased a Samsung Over the Range microwave smells hot
are you using the rack inside all the time only use the rack when you have something on it. other than that contact 1-800-samsung
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
1helpful
I have broken handle on the GE Spacemaker Model JVM130H. Can this be replaced and how?
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number(s) for a replacement door handle is WB15X10119 and WB15X10120. The door handle on this model has two pieces.
If you have any questions, please post back with your model number and let me know. I hope this helps you
I have a Samsung SMH 8165 ST that just quit. It
If the oeven was only purchased ij August it will be covered by manufacturers warranty, just check the air intakes are clear of debris first though.
Hope this helps
1helpful
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
