Vacuums Logo
Helen Posted on Jan 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dyson animal dc44 it doesn't seem to be charging I have bought another battery but still making the same noise that the battery is dead and motor won't start :-( thanks Helen
  • Official Brand Answer 2,572 Answers
  • Posted on Jan 12, 2016
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1770424
Points
6009
Hi Helen, it's Allan at Dyson.
I am sorry for the delay in contacting you.
If this isn't a power issue, then I would suggest it is an issue with the main body. This would be better discussed with an agent over the phone as they can run through diagnostics with you.
Please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
I'm sorry I couldn't be of any help directly and I apologise again for the lateness of the reply.
All the best,
Allan
Rick Offinger
Level 2:
Scholar:
New Friend:
  • Expert 46 Answers
  • Posted on Jan 07, 2016
Rick Offinger
Expert
Level 2:
Scholar:
New Friend:
Answers
46
Questions
Helped
29077
Points
182
The trigger switch, if not functioning properly, appears to be a likely suspect for this vacuum. You didn't mention what type of "noise" you are hearing, but if it sounds as though the motor is attempting to run then check to make sure you haven't picked up something that is binding the roller brush and preventing it from turning. If neither of these suggestions helps, you would would appear to have a motor or charger issue.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Apr 18, 2009
SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Anonymous
  • Posted on Jun 01, 2009
SOURCE: DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Samyfam
Samyfam
  • 379 Answers
  • Posted on Nov 07, 2009
SOURCE: dyson dc14 died, no power after burning smrll
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Testimonial: "thanks so much for taking the time to reply...sounds like we need a replacement!!!...will get the dyson ball this time..hope it's good! thanks again!"
Anonymous
  • 167 Answers
  • Posted on Apr 20, 2010
SOURCE: A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Anonymous
  • 23 Answers
  • Posted on Jul 05, 2010
SOURCE: Makes a whistling sound when turned on
bearings in the brushroll might be siezing.
If you start snapping belts, change the brushroll.
Testimonial: "Thank you for the feedback!! I think it is about time to replace the brushroll anyway- it is 6 years old and has had alot of use. "
My Dyson DC44 makes a small 'electrical' noise when I push the button, but does not start the motor. I have bought and installed and fully charged a new battery, so that is not the issue... any suggestions...
You will have to send it back to Dyson for service. There are parts available, but nothing related to the motor. My guess is the start capacitor on the motor. You can try giving the motor area a flat handed slap. It sometimes helps seat the carbon brushes.
https://vacuumdirect.com/collections/dyson-vacuum-parts/dyson-dc44-vacuum-parts
2answers
My Dyson DC44 Animal is not charging.
Here is how i fixed my Dyson dc44 not charging, it turned out to be easy, but i went through checking everything else on the way to find a simple fault and fix
1helpful
My Dyson DC44 animal has the MAX light on all of the time but it appears empty....any ideas?
ring dyson for support it could be the micro particle filter is blocked up and needs cleaning.
Dyson have really good support
http://www.dyson.com.au/support/dc44/dc44-animal-bu/maintaining-your-dyson-machine/wash-the-filters
Is the charger dead?
Hi Malgorzata, it's Jack at Dyson.
I'm sorry to hear your machine isn't charging. In order to confirm whether the fault lies with the charger, battery or main body, our experts would need to talk you through some simple diagnostic checks when you have your DC44 easily to hand.
When convenient, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Dyson DC44 Animal - after recharging battery, motor won't start?
Do not leave it to recharge overnight! Try recharging it again but just for the time it needs, and then unplug. Then try vacuuming.
This worked for me when I had the same problem.
Not starting at all
Hi there, it's Jack at Dyson.
The issues with your DC44 Animal sound unusual, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
I have a new Dyson DC44. It has a screw rather than a push button to remove the battery. I bought a spare battery. When I unscrew/loosen the screw, the screw won't come out and the battery won't pull
Hi Mike, it's Jack at Dyson.
Our cordless vacuums including DC44 Animal now include a fixed battery which is not designed to be removable in everyday use. As DC44 offers a runtime of up to 20 minutes of high, constant suction, we've found Dyson owners don't usually need an additional battery to complete cleaning tasks.
The battery is removable if it ever needs to be replaced, but we would advise against attempting to swap the batteries in normal use as the machine isn't designed to be used in this way.
For further advice I'd encourage you to contact our Support team directly - you can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
DC 44 animal wont charge. Charge light comes on then off after about 30 seconds.
Hi Darren, it's Jack at Dyson.
I'm sorry to hear you're having difficulty recharging your DC44 Animal. It should charge from flat within 5.5 hours when connected to the charger assembly, or placed in the docking station, as shown in the video above.
The charge light will turn off once the battery is fully charged. If it seems to be shutting off prematurely, we would need to take you through some quick diagnostic checks when you have the machine to hand. This will help us confirm what may be needed to resolve the issue.
Please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA), to speak directly with our team of experts.
Best wishes,
Jack
www.dyson.com
Loss of suction
I'm sorry to hear you've had difficulty with your DC44 Animal. It's normal for air to blow out of the back of the machine - this is where the exhaust air is returned to the room after passing through the cyclone pack.
However, if your machine doesn't seem to be picking up as well as usual and you've recently washed the filter, this may be due to a blockage. To check the motorised carbon fibre floor tool, wand and bin inlet for any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
The motorised carbon fibre floor tool is driven by it's own motor, rather than the machine's airflow. If it isn't rotating, the video attached should help you locate anything which could be jamming the brush bar. Make sure you remove any threads or hair from around the brush bar carefully using scissors, taking care to avoid causing any damage to the bristles.
I'm confident this will resolve the issue, but if you would like some further help you can reach the Dyson customer Helpline directly by calling us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack - Dyson Online Customer Support
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
