Hope someone can help me out with this. We have a Samsung fridge freezer RL38SCSW. I've used it for 4-5 years without a glitch. Past few days I've notice the very top section is nowhere being cold warmish, and in the freezer section has white powdery snow forming that i've never seen before. right aroung the drawers and inside the edges of the main door. The bottom half of the fridge is coolish but the top one is barely warm. How can I sort this out ??
Sounds like an air leak around a door seal or the ice maker chute door is open causing frost buildup on evaporator and everything inside the freezer. You also may have a defrost drain line blockage
APPLIANCE 911
Testimonial: "Thanks. Its been sorted. Opened the back panel, including the 2nd one which is grey. there was a small passage that going into the fridge that was blocked with ice. all the coils were clean and not iced over or frozen. just that little opening that was blocked with solid ice. Haven't opened up a fridge before so pleased to get it sorted."
SOURCE: Have a samsung side by side fridge freezer,but
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
FIXED :0)
