Tried vs and r gain already and not sure if the jumper is for this particular problem the eraser didnt seem to do anything but i could have been cleaning the wrong contacts. Need some straight answers.Test pattern doesnt do it and it has to be a moving image thats bright. turned down cell light and it now really just goes from bright to dark like a slight fade. menues when its doing this has a residual image. tried the screen scroll and no signs of burn in.
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you: http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HP-R4262&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=HP-R4262
SOURCE: Display problem with Samsung 40'' LCD.
This is usually an issue with the TCP (Tape Carrier Package) on the LCD panel prying loose. You need to wedge something on top of the TCP in the problem area that will apply pressure (rubber or foam. That will do away with the lines.
SOURCE: my brightness keeps resetting
i had the same problem....... on the actual tv u have to press and hold the volume button and menu button together for about 5 seconds and then on the screen it should say dynamic and that hopefully will sort it for u. Worked for me :)
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
