Why can I receive incoming calls, but when I try to call out, I get a busy signal
SOURCE: NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
SOURCE: no connection outgoing and can't answer incoming calls
I unpluged all hand sets for an hour,when I reconnected the hand sets they worked fine.
I unplugged base connection for about a minite and then reconnected and they started working agian...Thanks
SOURCE: how to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
SOURCE: My Intercom Extention shows busy. I have
With the exception of not being to dial out, it sounds like your DND or do not disturb button is on,The feature can be turned back off by either pressing the DND button again or entering feature #85.
