Question about Electrolux Washing Machines
Electrolux 1087 front load washing machine showing error code E50 on start. what can I do.
Recently relocated. Will not operate. shows Error Code E50. I have tried the door. I have tried reclosing the product draw Which seemed to help but the machine only progressed to fill but no wash and no spin and no empty. I emptied via the pump door.
New pump? ???
Posted on Jan 06, 2016
6ya staff
SOURCE:
Anonymous
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
Anonymous
SOURCE: Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
Posted on Mar 08, 2008
Anonymous
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
torres No9
jamie bryce
  • 27 Answers
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
Posted on Jun 25, 2010
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
Dec 21, 2014 | Electrolux Heating & Cooling
Electrolux front loader E50 error
Hello Friend, thank you for your post!
I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
Electrolux EWF1090 front laod washer not starting cycle? Error E50 is dusplayed on panel, however product manual has no reference to error E50? - NEED HELP
e50 is a motor error code,, this could be the motor itself of the wiring harness or the main computer board
Jan 26, 2011 | Washing Machines
ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Jul 24, 2010 | Zanussi ZWF1430W Front Load Washer
Bluetooth not working in nokia E50
same problem here. How to i restore my security code?
Jul 01, 2009 | Nokia E50
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Washing Machines Logo
242 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
