If we have no pizza, and divided it between you and me, how much do we get? ZERO.
However, you want equivalent fractions to 0/2. To get an equivalent fraction, you multiply the numerator (the number on the top) and the denominator (the number on the bottom) by the same number.
The denominator is that number on the bottom of a fraction, so with 2 different fractions you want to get them in a form where they have the same denominator. Often you will be trying to find the lowest common denominator.
The usual procedure is to multiply one denominator into the top (numerator) of the other fraction. Then repeat this process with the denominator of the second fraction multiplied into the numerator of the first fraction. Then multiply the 2 denominators together and the result is the denominator now of both fractions.
Eg 2/3 and 5/7 become
14/21 and 15/21
Sometimes further simplification is possible where one fraction has a denominator which is a mltiple of the other. eg
2/3 and 5/6
In this case you only need to multiply on the first fraction
A number with a periodic decimal representation cannot be equivalent to a fraction with denominator 10 (or a multiple of 10) except if the repeating decimals are zeros. 0.454545...=45/99=5/11
Equivalent fractions are fractions that have the same value. 2/6 is equivalent to 4/12, 8/24, 16/48. From a given fraction you can generate an infinity of other equivalent fractions by multiplying the numerator and the denominator by the same integer. All the equivalent fractions can be generated from a single one, namely the fraction that has the lowest numerator and denominator. This one is called the reduced fraction or the reduced form of the fraction.
When you have a fraction you can try to simplify it: You look for a common factor in the numerator and the denominator and you divide both by it. Keep doing so until you can no longer find common factors to cancel out. The last fraction whose numerator and denominator have no common factor is the reduced form of the family of equivalent fractions.
It is simple. 36=4x9 and 63=7x9. The number 9 is a common factor in both numbers. You can simplify the fraction by dividing both the numerator and the denominator by 9. 36/63=(4x9)/(7x9). You can rewrite the fraction as (4/7)*(9/9)=4/7 because 9/9=1. The reduced fraction equivalent to 36/63 is 4/7. Since 7 and 4 have no common divisor you cannot reduce the fraction further.
