Question about Ingersoll Air Tools & Compressors
Motor turns and pump pully does not. burning up belt.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
If you take the belt off, see if you can turn the compressor pulley by hand. If not, the compressor is seized and will need a strip down. Have you checked that there is oil in the compressor crankcase? Usually, there is a sight glass to check.
Posted on Jan 05, 2016
    Top Expert:
  • Ingersoll Master
  • 9,098 Answers
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
6ya staff
SOURCE:
Belts keep breaking 919.167600
If the motor is breakng belts that fast, most liketly your pump parts aren't turning freely. This is usually caused by a damaged bearing(s). With the belt off, all pump parts should turn freely and smoothly by hand with some more effort needed during the compression stroke. Check for smooth operation of the flywheel bearing, the piston rod bearing, and the piston/cylinder operation. If any of the bearings are damaged and hindering the turning of the flywheel, the motor will burn through your belt.
Jul 19, 2012 | Craftsman 26 Gallon Air Compressor with...
I have a Kenmore Dryer Model number 66902691 that has a burning smell when it is running. All lint was just cleaned out of it, but it is still smelling!
This might be caused by a seized idealer pully, located on the bottom of the dryer drum. A belt wrapes around the drum and across the idealer pully and then on the motor pully. If the idealer is not turning freely, it creates friction and eventually burns the belt in half.
Hope this helps
Apr 29, 2011 | Washing Machines
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
How do i replace my water pump on a gmc yukon xl 2002
First you will need to remove your tension belt from all your pullies. This is usually done finding a pully that provides tension to and takes away from the belt. HINT: It will be one that doesnt have abunch of mechanical part atached behind it. After removing hte belt in the center of the motor about mid ways up there is a pully that has a hose runing behind it. The other end of the hose goes to the radiator. Well where this plugs into the motor is the waterpump. you more than likely will need to remove the pully from the pump. afd88a0.jpgAbove is a picture of your pump with the pulley removed. The four bolts in the center are how you disconnect the pulley and the four on the side of the pump are how you disconnect from the motor. Make sure when you get done and all back together to look around the new pump for leaks.
Oct 24, 2009 | 2002 GMC Yukon XL
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Oct 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Machine has dificulty agitating, front pully has signs of melting, final spin starts slow but eventually picks up
The motor will have to be replaced if bearings are out. However, the smell you describe sounds like the belt slipping, which means something else is binding up. With the belt removed, turn each pulley and double check each one. A water pump is much more likely to fail than a motor. Good Luck
Oct 07, 2007 | Admiral AW22 Top Load Washer
Quit . Will not do anything. I checked the power to the machine.
see if you can turn by hand.. the transmission pully and pump pully.. sounds like one of them is bound up, the smell was probly the belt burning with nothing starting to spin
Sep 01, 2007 | Maytag PAV2300 Top Load Washer
Air Tools & Compressors Logo
142 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
