Singer Stylist 7258 Electric Sewing Machine Logo
Julika Alexander LaBrooy Posted on Jan 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When turning on the maschine, the number "E7" appears on the screen and a loud noise is heard.
R.A. Ellis
Level 3:
  • Singer Master 12,731 Answers
  • Posted on Jan 05, 2016
R.A. Ellis
Singer Master
Level 3:
Answers
12731
Questions
Helped
2618806
Points
59176
Try this:
http://www.fixya.com/support/t18116338-reset_e7_error_message
Contact Singer Support for assistance.
Unusual loud noise in Bernina 430 bobbin case area
Check the hook/shuttle to see if it is damaged
or check the race, the metal track that the shuttle/hook glides in there may be something jammed into the race
be very careful trying to remove a broken needle as you may further damage the race
My juki g210 is loud when I sew. its 2 months old. I cleaned under plate and bobbin, put in a new needle, and its still loud. what else should I try
put some felt or rubber mat under the machine
online reviews dont say they are noisy during operation
While sewing on this machine, I heard very little in terms of machine noise. The motor is almost whisper quiet. There is no vibration.
1helpful
My machine will not sew on it's own.
Wife says it will likely have to be repaired by a machine specialist in your area. Sometimes when that happens, the time gets off and needs to be repaired. It works when you turn it because your going much slower than the speed the foot pedal goes.
3answers
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
1helpful
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
3helpful
2answers
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john-michael_38e8d20d2052609c
Bernina troubleshooting
Bernina 880 - the dual feed will suddenly start making a loud "clunking" noise and making very tiny stitches. Then just as suddenly it will begin to work again - but the stitching is clumped, uneven with loops on the back. Then it will start working fine again until the next time... I called the dealer and talked directly with the repair person. He had never heard of that before. Anyone have any answers? Did I get a lemon?
1helpful
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
1helpful
Hello. My sewing machine DDL 5550-6 display shows the problem. E7. What is it? And how do I fix it? Thank you
HI THERE
concern E7 there's many reasons :
1- machine jamd ( try to turn machine by hand if you found handwheel is move easy ok.
2- thread trimmer locked or release? sometimes E007 come at the time of thread trimming function activated.( please check timming cam for thread trimmer ).
3- sometimes some threads go insaide hook and machine stop and give E7.
best regards
ashraf abozid
CAIRO - EGYPT
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
