Computers & Internet Logo
g
gamaliel ovivir Posted on Jan 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I upgraded windows 7 to 10 but problem occurred, then I tried to recover to 7 again, error appeared, 323:41, 319 and 329
Level 3:
  • Sony Master 19,187 Answers
  • Posted on Jan 05, 2016
Sony Master
Level 3:
Answers
19187
Questions
0
Helped
4342004
Points
82259
This is most likely from the drive being wiped including the recovery partition.
1helpful
How to stop 'No Sitemap Found' error in Lotus Notes?
In case you get the error message, while trying to open your mail file using the icon on the workspace, you can dismiss the error message and close all the opened tabs of the mail file. Go to the workspace and use the icon to again open the mail file.
Notes: The 'No sitemap found' error message usually occurs when you open the mail file from the workspace, while mailbox and calendar tabs of a previous session are still open.
There are various other ways to fix such error messages and issues occurring in Lotus Notes. In case you are still not able to see mail items in the mailbox folders, you can use various techniques to recover inaccessible or lost mail items from Lotus Notes.
Since, Lotus Notes is a professional software, used mostly in organizations for an efficient communication; it is advised to use a professional tool to overcome any issue including data loss situations.
Recovery Toolbox for Lotus Notes is a highly efficient tool to recover user mailbox items like emails, contacts, notes, journals, etc. from corrupt or inaccessible Lotus Notes database files. With the ability to display preview of all the recoverable items, the tool ensures an efficient recovery process. The recovered files can be then saved in any desired location. In addition, the tool is widely compatible across various versions of Windows operating system including Windows 8, 7, Vista, Server 2003, XP, 2000, and NT (SP6).
Here the link: https://recoverytoolbox.com/lotusnotes.html
Status 0x00000e9
Many of the problems caused by programs lead to the emergence of the messages that come in shape
A fatal exception XX has occurred at XX.
Often occur, because the program on the problem of improper code required Processor Processor you make improper operation. Thus Windows displays this message to tell you so and ask you to tell him what it must do. In fact, these kinds of errors do not escape them and often lead to the closure of the program or you may have to restart the Windows operating system as a whole and therefore you will lose any unsaved data before, and you models for these errors.
He noted that in all the solutions that Snordha here we'll use the letter A to represent the floppy drive and the letter C to represent the hard drive that contains the Windows system device and the letter D to represent the CD-ROM drive, and that all the messages and solutions applicable to Windows XP and Windows Me unless stated one only.
Message:
A fatal exception 00 has occurred at XX
Meaning:
This error occurred because the processor tried dividing the number to zero which is the correct thing is sporty and therefore this letter appeared.
Solution:
Close the message and try to continue to use the program, if you can not close the program and then restart it again, or restart your computer if necessary College.
Message:
A fatal exception 0C has occurred at XX
Meaning:
This error occurred because one of the instructions stored within a certain part of memory called the stack (which parts of memory are reserved for programs to deal with the equipment and devices) tried to use portions of memory outside the specified part
Solution:
Try closing the program and restart your computer.
Message:
A fatal exception 0E has occurred at XX
Meaning:
This error occurred trying to access the data processor located on the Page page of memory RAM or virtual memory Virtual Memory, but discovered the absence of the page, or that the data has been improperly accessed.
Solution:
Close the message and try to continue to use the program, if the program can not switch off and then turn it on again, or restart your computer if necessary College.
Message:
A fatal exception 13 has occurred at XX
Or General Protection Fault
Meaning:
Fault of the same quality as previous mistakes, but did not specify why.
Solution:
Close the message and try to continue to use the program, If you can not do close the program and then restart it again, or restart your computer if necessary College.
All previous mistakes are supposed to occur at intervals spaced opposed, if repeated occurrence tried to determine when those errors occur, if they occur while the program is running, you may be able to solve the problem, remove and then reinstall the software again, or get a version upgrade him.
If you can not link between the error message and a program may be the reason why a file from the Windows system files or one of the device drivers Device Drivers, and test it restart your computer in the security mode Safe Mode, if you do not see the message usually be the cause of one of the players devices Thus you can access the latest version of the drivers in your device through the companies that produce them site on the web, and if the message persists often will be a problem in the Windows system itself, and therefore you will need to re-set the Windows system again.
Message:
System busy and appear on a blue screen
Meaning:
This message appears with the nature of the error usually as stated in previous communications with the program said that the cause of the problem is the system may be Windows itself, and ask you to wait until the system becomes less busier.
Solution:
Restart your computer, and if the error is repeated several times do to deal with him as we have seen in previous communications solutions.
I Have installed windows 7 but it hangs and then a error will appear wrriten windows vista is succsfully recovered, but recently it gets hanged and a blue screen appears wrriten an error occured and w
  • Update all your "Drivers" and install all "Windows updates" from Windows update and "Scan" your computer for viruses! And I also suggest you to run CMD as "Administrator" and write in CMD without quotes"sfc/scannow" this will fix blue screen error.
  • If problem still exists, then get the reliable program Reginout to resolve your annoying issueof blue screen. Thanks
A type of error on windows
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
switch.
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
again.
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
required.
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
2helpful
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
I can't finish installing yahoo, error 0xc0150002 appears. What can I do? I'm using xp home basic. I had Yahoo 9 installed, uninstalled it and downloaded Yahoo 10, but when it was allmost installed,...
This behavior may occur if you install Windows XP Service Pack 1a (SP1a) on your computer, and do any of the following:
  • You upgrade your Windows XP Home-based computer to Windows XP Professional.
  • You reinstall Windows XP on your computer.
  • You perform a repair of Windows XP on your computer.
To resolve this behavior, after you upgrade your Windows XP Home-based computer to Windows XP Professional, or you perform a reinstall or repair of Windows XP, reinstall Windows XP SP1a on your computer.
After you reinstall the service pack, restart your computer.
try this and tell me incase if any issues
Boot up cycles, windows appears, but reverts back to boot
It may just be a default setting in the new BIOS. Enter the BIOS setup and check the SATA mode - I've seen this occur with the ACHI mode for example. Otherwise you could try Safe Mode and see if you can get into Windows at all. You can also press F8 while booting and select the option to Disable Automatic Reboot so that you can see the Error that is occuring for further diagnosis.
Boot failure after upgrading bios asus p4xp-x
You have accidently corrupt mother board BIOS,you have to replace it ...no other choice...
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
