AOC 936sw 19" Widescreen Lcd Monitor - Black Logo
Anita Sanna Posted on Jan 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I attach this monitor to my laptop to use it as a second screen Please?
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 04, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067972
Points
28436
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
No signal monitor F-417
screen has been identified and installed but you need to send laptop signal to this second screen
there will be a key on the keboard or you can right click the desktop then proceed to send signal to the attached second display
My Pres C300 laptop works fine with an attached monitor. But its own LCD screen is currently having 3 equal horizontal sections. First (top) section is normal, second flickers and is normal when pressed,...
Since the laptop works fine with an attached monitor, it means the problem is the inverter.
The problem with your laptop screen is that the inverter is malfunctioning, that is why you have those three equal horizontal sections.
Change the inverter of your laptop screen and you will see that the screen will be stable back.
Take care.
1helpful
2answers
Using two monitors attached to my lap top and can only use one of the two screen
  • Attach two monitor and switch on the laptop
  • automatically second monitor will show diplay
  • if not then find out dual display symbol on the taskbar click on it.
  • window will open select dual monitor
  • click apply
  • if not then right click on desktop --properties--desktop two monitors symbol will see select 2nd monitor
2answers
How do u connect a ei53fp monitor to a 1336 by 768 reolution laptop
Attaching a second monitor to a Laptop, if its fairly new, will automatically load a second display. Right click the background on your LAPTOP screen and select properties after you attach the monitor cable. Go to settings. You should see two monitors. If not, you need to press Fn+ F6 on most Laptops to activate the second monitor. See your owner's manual on function key (Fn) Choose the second monitor screen and set the desired resolution.
2helpful
Want to put a extra screen
You can attach a external monitor to it yes. Once you have purchased a monitor and attached it than you press Fn F4 should be twice to use both monitors. Please make sure you have a video component on your laptop so you can arttach the second monitor.
Hope this helps ^^. Please dont forget to rate, Thanks
1helpful
2answers
Laptop doesn't see the monitor i attach to it
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Gateway flat LCD dead
I'm not sure if your referring to the lcd monitor (gateway brand) or a laptop's lcd screen not working anymore.
1. if it's an lcd monitor...
a. test monitor in a different pc before assuming the problem is the lcd screen
b. replace the monitor if after testing monitor is in deed the item failing.
2. if it's the lcd screen from your gateway laptop.
a. you may be able to attach a regular analog monitor to the paralel port on your gateway.. test and see if the monitor that you attach will give you a picture (you may have to toggle with some some keys on your laptop keyboard to make have the signal going to the "externa" or attached monitor.
if the other monitor does not work either.. you video controller on your motherboard on your laptop may be failing and you may not have other options that to replace your laptop.
b. if the external/attached monitor works.. very likely the problem is the lcd screen for that you need to get a replacement and you may have to contact gateway to find out about pricing (or places to send your laptop for service if you're still within warranty). if you have an old laptop you may have to considere simply replacing the unit as buying a new lcd screen may very likely be more expensive than the same working laptop.
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
