Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Ian Lulham Posted on Jul 15, 2009
My Craftsman Garage Door opener stopped working.
We recently had a storm and lightning struck somewhere nearby. When you push the wall opener or the remotes there is no response. What is the most common parts failure in this situation? The board or the motor starting capacitor?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1339
Points
5
The most common part to go bad in these openers when lighting hits them is the logic board. Look for a white and black label that has your model number on it. Go to http://www.usdoorcontrol.com/manufacturers-other.html and find the newest revision board that is made. Repairing this problem is easy.
3helpful
After a lightning storm, my LIftmaster Formula 1 garage door opener will not close without continually holding down the garage door button on the wall. If you push the button once and then let go it will...
If when the door reverses the main light flashes 10 times you have a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. They must be pointed at one another for both lights to be on. If you cannot get the lights to come on you have a bad logic board.
AFTER A RECENT ELECTRICAL STORM AND A NEARBY LIGHTENING STRIKE THE GFI PLUG BLEW. ONCE RESET THE GARAGE DOOR MOTOR WILL NOT FUNCTION. LIGHTS COME ON - I RESET THE REMOTES BUT NOTHING . AT FIRST THE MOTOR...
I would pull the logic board and check for burnt or missing traces on the printed circuit. Garage door openers hate electrical storms. I really doubt it got to your start capacitor.
3answers
No reponse when using the remote, the wall control works fine.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
Same problem same day
Unfortunately there isn't a reset switch but I would pull the logic board and look for burnt or missing traces on the printed circuit board. Electronics do not like lightning.
1helpful
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Craftsman garrage door opener not operating after thunder storm
If you had an lightning storm you most likely have a bad logic board. That is not a reset button you are pressing.
Both openers stopped working at the same time but they are both plugged in to an outlet that still has power. The lights are out on the opener wall switches. Wife thought she smelled electrical smoke when...
what openers? Sears/liftmaster of last 2 years have no reset. Sure power to outlet? Try a lamp. Did a gfi trip. Did wife run both doors to overheat them. they should cool off in 15 minutes. Do you have a surge protector. Did it go bad. Some kill power when they get cooked. Did you have a lightning storm. Culd have cooked logic boards.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
