Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
SOURCE: Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
SOURCE: HELP
how many times does it blink it should blink a two digit code. let me know the sequence of blinks as it should be a self diagnosis code
SOURCE: Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Testimonial: "Thank you very much."
SOURCE: red and green
Replace both of your STK ICs they are big black ics will have part number on them STK392-570
Call Mats 1-800-628-1118 Parts are 10.95 each
SOURCE: I receive a blank blue screen even though my DVD
i would try other inputs and see if you can get anything. some of these tvs have a bad 9v regulator on the signal board that powers the video switch. if it goes bad, you wont get any video at all on any input, but you will still get menus and sound
its like ic9c25 its a ba09 regulator
