Take it back and for an exchange.
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
SOURCE: Panasonic DMR-ES30VS DVD Recorder / VCR Combo Troubleshooting
SOURCE: Curtis DVD-7620 (7600 series) Combo VHS / DVD Player - what is remote code?
It all depends on the brand of remote your trying to program,for a nexxtech the codes are one or the other 0929 or 0928.
Try typing in the search engine for example Curtis vcr/dvd7600 RCA universal remote codes. You may get better results.
I hope this helps you.
If not at least you will learn how to use the different code retreival methods they don't tell you in the booklets/pamplets that come with them or if you lost it.
Good luck
SOURCE: HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
By using slysoft software(www.slysoft.com) you can make a copy of the disc on your computer which will remove the encryption code. Then you can take the new disc and copy to vhs.
SOURCE: No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
SOURCE: Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code-
free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
