Question about Kenmore Front Load Washer
Stuck in spin cycle - Kenmore Front Load Washer
My washing machine is stuck on the spin cycle. Help! How do I correct this problem quickly and easily?
Not sure what you mean by stuck on spin cycle. If it will not stop spinning, then timer or control most likely would need replacing.
Sep 19, 2017 | Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
How can I find out if there is something stuck in the machine. Things still wet after spin.
It could be two problems. Check the hot and cold water inlet valves, it should be completely close at the final spinning cycle. Another thing is water outlet pump it should be run on the spinning cycle. Something might be stuck in the water pump.
Feb 01, 2015 | Washing Machines
Why is my washer stuck in the spin cycle
hi
this might be too obvious but did you try to unplug the washer for at least 5 min to completely reset the computer in the washer ?
Jun 08, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore Front Load Washer Logo
54 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
