Question about Microsoft LifeCam VX-1000 Webcam
Trasfer ring photes ft tab to micro so when it says erase everything then continue what do I do.
I have done required now I am on last step where I am supposed to erase everything to SD card but does mean I will lose the document on my data.
    Top Expert:
  • Microsoft Master
  • 9,098 Answers
Can you back up the information before trying?
Posted on Jan 01, 2016
6ya staff
SOURCE:
I have a digital camera 4.1 megapixel i can not get my photes to show dont know if they were accidently erased or not please help me find my photes and get my camera to take photes correct again
Hi
Take the memory card out of the camera and try to read on your computer through a memory card.You might find the photos you are looking for. If your memory card is good you can try to recover the erased photos using the recovery software which are easily available. As far as the camera is concerned you have not mentioned what is the actual problem, so i will not be in a position to give a solution for that.
Regards.
PLZ. don't forget to rate my solution.
Jul 14, 2011 | Cameras
I want 2 trasfer my mobile photes 2 my pc.i didnot my mobile software cd
Configure your Email on your mobile and then send pictures attachments to yourself. Then open your Emails in computer.
Aug 08, 2010 | Computers & Internet
I cant remove the write protection of my kingston
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 15, 2009 | Kingston Technologies 512MB DataTraveler I...
Sansa e200
Ah, the Blue Ring of Death - Make sure the hold/lock is not engaged first. You will need to update the player's firmware and possibly use the Sansa Recovery Tool.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 26, 2009 | SanDisk Sansa e250 MP3 Player
Hangs on startup unacceptable!
Most mp3 players don't make it a year - extremely high failure rate:
-Tha Mp3 Doctor
Oct 26, 2008 | SanDisk Sansa e250 MP3 Player
Frozen sansa e250 MP3
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 26, 2008 | SanDisk Sansa e250 MP3 Player
Kyocera 5135 Cell Phone - erase all
when u take the sim out the call log should be gone or try
the defult code 1234
or 12345
or 0000
or 00000
Jul 18, 2008 | Cell Phones
Sansa Fuze
Probably a hardware/power supply issue (would require a replacement), but you can try my soft fixes:
-Tha Mp3 Doctor
Jul 06, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 (only blue ring lighting)
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 29, 2008 | SanDisk Sansa e250 MP3 Player
My MP3 player will last about a half hour on a new battery. Iwould like to know how to take care of it and how do I get in touch with the company?
Call Wal-Mart, b/c ILo is out of the mp3 business
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 07, 2008 | iLO (2 GB) MP3 Player
Microsoft LifeCam VX-1000 Webcam Logo
219 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
