SOURCE: canon iR2016 zerox machin shows
these means that you have fixing trouble, probably low or high temperature.
You can clear it in service mode.If it doesn't help you need to change fixing heater.
press *
press 2
press 8
press *
By arrows navigate to CLEAR
press OK
navigate to ERR or ALL
press OK
Turn off and on
Hope that helps!
Notice that under my tips and tricks you have ir 2016/2020 error codes and how to clear certain codes.
SOURCE: usb to not detect ir2016j canon xerox machine
Usb to not detect ir2016j canon xerox machine.
SOURCE: My Canon zerox machin ir 2870. my machin dosnot open Error code is E000733-0001
Dear
(E 733-0001)(There is an error in the communication with the printer-
There is a DDI-P communication error.)
Pl. do.
1. Check the connection with the
printer.
2. Check the power supply of the
printer (to see if initialization takes
place at startup).
3. Replace the DC controller or the
main board.
Thanks.
