SOURCE: I have a Tork timer model number 1101 24 hr time
Tork 1101 is a 120V mechanical dial-type timer
Tork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
SOURCE: I have a Tork 1101.
Tork 1101 is 24-hour 120Volt mechanical dial timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
SOURCE: Tork pool timer dial, spins freely, not keeping
Timer is not 100% identified.
120Volt Tork 1101 timers can be fixed with repair parts.
Generally, plug-in-outlet timer has gone bad, then it cannot be fixed.
Open following links to identify timer and then add a comment.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Add a comment for more help
Upvote the help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
