Question about Timex Expedition Watches
How do I set the time. Style #t40091 - Expedition Timex Watches
How to set time on seiko qhr017s travel alarm clock
Did you ever figure it out? I have the same problem. I see no one answered you here.
Feb 09, 2014 | Gift Warehouse Seiko Silver Tone Atomic...
How do I set the time on a Cedarwood State ION Sports Watch
the instructions to your watch are the same instructions to a breo watch of similar style
Mar 27, 2011 | Watches
How do I set the time on this watch?
Hi, function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
I had a watch similar, and it's actually very easy to adjust as soon as you have the solution, so:
You need a very thin stick (maybe a toothstick or a think pencil). 1) Stick it into the upper pinhole (on the right side on the watch). Then it starts to blink. 2) Adjust by pressing the lowest pinhole 3) Confirm with the upper pinhole 4) Now you'll go through each step (hour, minute, date, 24/12h, etc.) 5) Finally you will se the time on the watch (not blinking), If you press the lowest pinhole you can choose between: - static screen showing time - static screen showing date - shifting screen showing both time and date
Br. M
Dec 14, 2009 | DKNY NY1304 Watch for Men
How do i adjust date and time
the knob at the side....
  • First pull which will change the date.
  • Second pull which will set the time.
thank you
Apr 06, 2009 | Orient Automatic Sapphire World Timer...
How to set the alarm on a seiko presage chonograph?
Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
How to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Sep 18, 2008 | Bulova Watch
Big problem
Push the touch button and then the centre of the screen untill the units deg C 24h etc come up then hold the touch button for 5 seconds. This puts it in sycro mode. You can then use the -+ buttons to make them both point to 12
Feb 24, 2008 | Tissot T-Touch T33759851
Old style citizen wr100 blue angles watch how do you set it
I need an instruction manual for a Citizen Blue Angels Navihawk WR100 watch. Can you provide a free manual?
Nov 15, 2007 | Citizen Blue Angels Skyhawk Watch
Watches Logo
64 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
pacdave
Are you a Timex Watch Expert? Answer questions, earn points and help others
