I did unplug the phone jack from the wall, the battery from the phone to no avail.
This could be several things.... the simplest is that a weak
handset battery can interfere with registration. Or,
does the handset display say "Connecting..." or
"Searching...." or "Out of Range / no power at base ..." ??
In these cases the handset is registered to another base and
must be de-registered before it can be registered again.
To deregister the handset:
Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say:
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..." and it should be ready to
register.
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
SOURCE: I have a Tesco Cordless
Maybe a little bit late, this is the solution for registering the handsets: hold the button on the base until it starts beeping, then, on the handset, go to the Register menu, select base number - in my case it's 2, then it will ask the PIN - the default is 0000, and that's it.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
