Olympus Stylus 710 Digital Camera Logo
Posted on Nov 17, 2007
D : 5e02
D :
5e02
  • 3 more comments
  • Anonymous Nov 18, 2007
    D : 5e02 error message
  • ztirf Nov 26, 2007
    D: fe02
    there is a blue background and D:5e02
  • Anonymous Nov 30, 2007
    error 5e02
  • Anonymous Dec 03, 2007
    if xoom is held out then it fixes itself
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
313
Points
If you hold the camera so the lens points upwards when turning it on it will then let you use it as normal.
Anonymous
Level 1:
  • Posted on Nov 17, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
313
Points
Not able to click pics.
Blue screen is coming with 5e02 erroe
Hello Sanjay -- NOT a good sign I'm afraid the 5E02 message is a PCB error.
I just checked a website for a manual with trouble shooting ideas to send you and the sites are full of 5E02 problems and the only solution appears to be - Take it back to a shop if under warrantee.
Problems were UK , USA & Australia -- (I use www.google.co.uk ) as my search engine and i typed
"olympus 5e02 error message" and it applied to non-focussing problems , no display etc
http://www.howtomendit.com/answers.php?id=120514
Here is one link as example -- Ray
1helpful
Olymus 710 will not focus error code 5e02
as your powering up slap the camera in the palm of your hand, the lens is out of adjustment
WHEN I TURN THE CAMERA ON, IT IS STUCK ON A BLUE SCREEN
a minha maquina não esta ligando, quando vou ligar ela aparece um codigo 5f08 e embaixo 5e02
8helpful
Getting error 5f08 5e02 in my olympus camera..
Getting error 5f0a 5f08 5e02 in my olympus camera..
5helpful
Stylus 700 error D:5f08 5e02
The error message (D: 5f08 5e02) means that your lens is dying / dead. It just happened to mine (on the Mju 700, but it's the same thing) and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
4helpful
2answers
Camera olympus error D: 5f08 5e02
The error message (D: 5e02) means that your lens is dying / dead. It just happened to mine and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08
i have the same problem with my camera it show 5foa 5f08 5e02 with the blue screen
6helpful
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08 5e02
this is the most common problem with the olympus cameras the lens has been knocked and by you pulling on the lens it sounds like you have done some damage to the motor that bring the lens in and out thats why its making that noise what you needed to do was move the lens either to the left or the right you will no when its fixed because the lens just pops out and the camera will be fine this works every time i just hope you havnt done to much damage alredy goodluck
Olympus Stylus 790SW "Blue screen"
appears to be repair issue and need to send to a repair center
2answers
Olympus digital code D : 5f08 5e02 Camera not functioning
Camera will not turn on and displays D :
5E02
shutter will not remain open then the above is displayed
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
