SOURCE: forgot lock code on LG EnV, need to reset settings for donation
I had the same issue with the same phone. By pure luck, I tried the last 4 digits of the phone number last used on the phone and it worked!
SOURCE: My daughter has an LG Touch GW620 phone and has
give it to lg service center and re-install ur os again.. simple
SOURCE: security code on my lg kp500
RESET ur fone using option "reset" whch U get after typing 1809#*500#
SOURCE: my LG phone is locked
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
type *#06# on your phone to get it.
go to the setting in your mobile and pess the restore factory settings and restart your phone
SOURCE: Lg Kg195 we would like to activate gprs. I
I want gprs setting for vodafone and lg kg195 pin for gprs activation
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
