Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I turned on my tv today, and it was darker than usual with bright red.
I unplugged the tv for a min. and turn it back on and it was the same
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 32 Answers
SOURCE: We have had this tv for 5 yrs. It seems the
5 years. Have you replaced your lamp. You might need a new lamp. Lamps usually last 3-5 years depending on how much you watch your tv. Call your local repair shop with your model number to check price of lamp
Posted on Jan 20, 2010
ELEMENT LED TV will not turn on
You have to check the power supply of the tv. Try to replace it then only you will be able to identify the fault. Is it the power supply or the motherboard
If you wish to get some more details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 16, 2016 | Element Televison & Video
Toshiba big screen tv black screen with sound
It is telling you that you need a new backlamp or that the power supply that feeds it is out. It could be bad Chinese capacitors or you may actually need a back lamp. The hint was when it was working did the side edges have a darker brightness to them? If yest the lamp is needed. If no then the capacitors in the backlamp supply may have decayed.
Oct 01, 2012 | Toshiba Televison & Video
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Red faces
You will need a qualified TV technician for this, as there are no user servicable parts in your set, but there are hazardous voltages present, even when the set is off & unplugged.
Oct 23, 2006 | Philips Magnavox 51MP392H Rear Projection...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
