Sharp VC-H982U VHS VCR Logo
Keith V Stracchino Posted on Dec 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can anyone supply me with the common commercial type number, JEDEC number, for the power supply output transistor in the Sharp VC-H982U video cassette recorder?
Grubhead
Level 3:
  • Sharp Master 5,755 Answers
  • Posted on Jan 03, 2016
 Grubhead
Sharp Master
Level 3:
Answers
5755
Questions
Helped
1662410
Points
11417
Type "Sharpe VC-H982U Service Manual" into Google and you will see a free PDF of it. That should tell you the number!
NEED OWNERS MANULE
Try the Sharp Website they might have a free PDF of it.
I have a Sharp VC-H982 VCR. Went to turn on today and it is not getting any power. Worked fine last night. I have moved the power cord to a different receptical, still nothing. Is there a fuse that may...
Hi:
If the unit is totally dead meaning no standbye light of or nothing on the display its dark, then you may of blown the AC line fuse. This is the first thing to check the fuse is inside the unit you can trace its location by taking off the top of the VCR and tracing the pwr cord to the point where it connects to the power supply, here is where you will find the AC line fuse use a ohm meter set on continunity to check the fuse for open condintion. If open or blown replace with same voltage and Amperage rating as indicated on the board or the fuse itself. If you find the fuse is good then you have a power supply standbye voltage missing and is related to the power supply. In which case it may be cheaper to just purchase another.
2helpful
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
1helpful
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
I have an audiobahn A8000t amp with the protection light on
Note:
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
1helpful
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Sharp vcr
I wondered if you were able to get a copy of the manual. Does anybody know how to reset the tamper proof button that needs a code. MY child seems to have set this with a code.. Any help would be much appreciated. Thanks
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
