Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
m
michael mccort Posted on Dec 27, 2015
Loud squealling noise instead of voices - Sony Bravia KDL-46V4100 46 in. LCD HDTV
1helpful
2answers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 • Dryers
Kenmore Elite HE5 front load dryer is making a loud squealling noice...Help?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
2answers
Dewalt dc759 drill squealling noise coming from
yes,the most coomon defect for poer tools are carbon brushes.But,git attention also to the gears,bushings, and bearings if there are loosen parts.Also you get rid to a debris or any small dirt particles that maybe sunctioned by the fan and has been entered in the body of the drill thats why you can hear an squealling noise..Just open and clean it.
2helpful
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Squealling noise while curving left
This is a symptom of a bad CV joint.
2answers
Loud squealing
sounds like shims on brakes, or lack of them
thin bits of metal to stop squeel
When dyer runs it makes a squealling noise like abad bearing>
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
It's screaming at me ~ squealling loudly.
the cutter wheels in side the machine needs to be lubricated. use a silicone lube. like tri-flo. Spray the lube where you put the paper
Washer spinning
Hi jmm119
Its hard to say what it is but it could be one of 2 things, either the belt ore the main bearing is gone. but my first guesss would be the belt.
brent
There is a squealling noise
THE SUPPORT AND SPIN BEARING IS BAD . WHEN THIS GOES BAD IT DESTROYS THE LOWER SEAL. MAJOR REPAIR . CHECK WARRANTY IT MAY BE COVERED. OTHER WISE REPLACE MACHINE.
FXIT
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
