Used to have a Macally brand over the ear headphones my SanDisk would plug into, no wires in the way, great, until they wore out
SOURCE: No left ear sound.
That happened to me. It is fixable, but you need to open the caseing of the mp3 player itself. what hapened was that one of the dongles connecting the jack to the main chipset lost connection. you probably bent the headphone thing too much and it released.
to open the sansa, you must take out the battery. then you should find 2 black screws near the edge of the casing. Unscrew them and take off the black plastic cover. You should see the bottom is now totally silver. Near the headphone jack there should be another screw, Unscrew it. These are the only screwes you will need to unscrew from now. Next, Pry off the screen cover to reveal the chipset. Remove the connection from the chipset to the button pad. Take a standard screwdriver and carefully pry out the chipset, revealing the headphone jack. Be sure that the 3 dongles hooking it up to the chipset are in place. Put some tape on however you like, just be sure its tight, and be sure it doesnt interfere with any of the side buttons. Then add some more tape underneith the dongle for more support (do this unless you have a sodder, then sodder the dongles back on. Put the chipset back in the casing and replace the faceplate (dont forget to connect the button pad back to the chipset), and replace the back thing. Put the battery back in and test it. If it doesnt work then add a little tin foil into the back on the dongle. It should work.
SOURCE: My SanDisk earphone jac has a shortage in it.
You must have knowledge in splicing cordial two-set wires. Hail!
SOURCE: I have a sansa mp3 player
the headphone jack inside the unit has 3 attachment solder joints the botton right connection point breaks free of the board. the way to fix it is to get a small phlips screw driver remove the 4 black screws on the back of the unit remove the metal back, then remove 4 silver screws on the outer edges inside the unit & remove the board from the front cover & with a soldering iron with a very small tip resolder the loose connector to the board be carefull not to over heat the board or plastic jack & just put the unit back together.
SOURCE: My sandisk when you put in headphones only one
Verify that you've pushed the headphone jack all the way in. Sansas tend to have very tight headphone ports.
If not, try other headphones. If the others do the same thing, it's likely that your Sansa is damaged.
