This means that the sensor is not plugged in or has been damaged. This Thermometer is a resistive device. If the thermistor is not connected the resistance is too high and thus out of range. The unit will then display the 'HHH'.
May 31, 2019 - ErrH - This is a code that will sometimes display on digital instant read thermometers. It indicates than an internal error has occurred and it will no longer read temperatures. This can be a result of drop/fall damage, water immersion/moisture buildup, or exposure to direct heat/flame.
Oct 19, 2017 - My ThermoPop is displaying an LLL or HHH error. What does it mean? There are several reasons your ThermoPop may display either an LLL or ...
The outdoor power unit failure(where indoor/outdoor power supplies are separated)
Indoor/outdoor communicationerror- Check power to out door- If not, in door PCB defective. Replace it.
A and B wiring reversed afterpower on-Rectify.
Thanks.
HHH on your breadmaker means the units it too hot to begin a new batch. Stop the machine, take out the bread pan and allow the unit to cool with the cover open.
If the receiver and/or the transmitter display LLL or HHH instead of the probe temperature,
wait for probe to reach room temperature. If LLL or HHH is still displayed it is likely the
internal probe wire has shorted out either through moisture or heat damage.
