Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
Have you fitted a memory card?
The camera will only take a few photos using its own memory.
It takes: SD Memory Card, SDHC Memory Card , SDXC Memory Cards.
If you have fitted a memory card it may be faulty and you will need to buy another.
What type and size memory card do you have in the camera? The C433 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Its just a problem with the sd card. try another sd card and transfer all data to the new one and see if the memory full problem shows in case of sd card. And check where is your default storage set to, to phone or sd card?, and if to phone then check the memory space available for the phone from the user manual. if its very low in size try to delete few sms and numbers from the phone book.
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Locate the Memory Card slot within the battery compartment.
Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
Formatting will delete all data on the SD memory card including protected data.
8
Don't remove the SD card during formatting as this may damage the card and render it unusable.
When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Check and make sure the SD card is in all the way, it should make a clicking sound when it's in all the way. I had this same problem with my Vivicam 8025. Hope this helps!
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
