Dealers are no help. I need a Hyd flow chart or any others check points I need. Lift arm levers are not stuck
Check that the tractor is still under warranty as 157 hours is not long for an engine
If it is the hydraulics will also be under warranty and if the dealer is no help then get the service manager of the distributor on the line and talk to him
if the arms worked prior to the engine change then they should work after the new engine or it is something the dealer did wrong
