Televison & Video Logo
Douglas Stein Posted on Dec 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have solid red light at the 7 o'clock and blinking red light at 11 o'clock
Tv is on and working properly
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 21, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067229
Points
28436
[PDF]Download XD1080 User Guide - Replay XD
www.replayxd.com/downloads/.../Replay-XD1080_User_Manual-EN.pd...
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
LG TV Blinking - YouTube
? 0:43
https://www.youtube.com/watch?v=Q8JG53DU6Rk
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
Diamond - ndxLocOut
www.nuforc.org/webreports/ndxsdiamond.html
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
[PDF]Air-Pak 75i SCBA - User Manual - Scott Safety
How do I fix my Sony TV?
Sir
please one thing remember that red led blinking indicate specie fault please watch red light count and find the correct fault which is written below
Monitoring Items Number of Flashes of red led Main Power Supply Voltage Error 2
DC_ALERT1 3
DC_ALERT2 4
DC_ALERT3 5
Backlight Error 6
Internal Temperature Error 7
Audio Error 8
Digital FE Error 10
Trident Error 11
Balancer Error 13
T-CON Error 14
thanks
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
2helpful
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Just replaced bulb and the tv still does not work? the green light flashes 9 times and the red light is solid
Howdy;
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
Good Luck, Big Irish.
6helpful
2answers
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
2answers
TH-42PX80U
i have the same problem but i have 11 blinks
2answers
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
