[PDF]DIGITAL CAMERA REFERENCE MANUAL - Olympus America
www.olympusamerica.com/.../stylus_300_400_dig...
Olympus CorporationExplanation of digital camera functions and operating instructions. Explanation ... This reference manual contains guidelines for using Olympus Stylus. 300/400 ...
Taking Manual Control Over Your Digital Camera - Digital ...
digital-photography-school.com/manual-control-digital-camera/
manual-control-camera.jpg. I was typing away the other day, putting the finishing touches on a short article, and not being the most careful typist, I accidentally ...
[PDF]Nikon Digital Camera COOLPIX 900 Reference Manual
cdn-10.nikon-cdn.com/pdf/manuals/coolpix/CP900rm.pdf
which can be determined by turning the equipment off and on, the user is .... Thank you for buying a Nikon COOLPIX 900 digital camera. The COOLPIX 900 is a ...
[PDF]User's Manual
Make sure the battery is fully charges and hold down the power button and it will power on
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
When you say 'put it on', could you be more specific ? Are you trying to attach a camera to a tripod, or turn on the power on a camera ? Either way, it would help if you could indicate the make and model of the camera, please.
