Washing Machines Logo
Joseph Wright Posted on Dec 20, 2015
Belt application Belt keeps slipping off
2answers
What would make the serpentine belt keep slipping off
Failed Water Pump
Crankshaft Damper Worn
Failed Belt Tensioner
Failed bearings in any accy
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Serpentine belt keeps popping/slipping off
The power steering pump pulley must be flushed with the power steering pump shaft,Or else you will have noise or slips right off.12_11_2012_4_28_42_am.gif
2answers
Cant get timming belt back on around crank pully
Are you referring to the timing belt or serpentine drive belt which works your alternator, power steering pump, etc? Will need to know specific engine details in either case and please clarify exactly what you are perfoming. Thanks, Mike
1helpful
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Cherolet 2000 malibu belt keep slipping off
SOUND LIKE A BAD BELT TENSIONER OR YOU HAVE WRONG SIZE BELT.
Serpintine belt keeps slipping off of middle wheel
If the belt keeps slipping off the you need to replace the tensioner(its the pulley you have to move to get the belt on and off,and that part should be inexpensive to replace from any parts store.
2helpful
460 motorhome fan belt slipping
Check and see if the pulleys are shiny looking, also are the batteries low on charge, if you have more than one battery the load on the alt is huge, add in a low or bad set of batteries and then the belt can deliver enough power to spin the alternator, and it slips. Worked on motorhomes for year's, saw this allot.
1996 buick regal custom's belt keeps shredding
The first thing i would do is try playing with the belt tensioner. it sounds like the belt is lose and when the engine warms up the belt starts to expand and slips off.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
