Clymer Evinrude/Johnson 2-70 HP Two-Stroke Outboards Includes Jet Dri Logo
Sammy Whitlock Posted on Dec 19, 2015
What should compression be on a 1994 Evinrude intruder 175
1983 9.9 evinrude runs good on land but will not accelerate under load
Possible wrong plugs, bad plugs, bad coil, bad wires, or any combination.
1helpful
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
1helpful
2answers
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Will a 1973 50 hp Evinrude OMC lower unit fit on a 1988 evinrude 50 hp
Tony, that's a problem for the boat motor repair section.
Nov 02, 2013 • Vacuums
Top Clymer Vacuums Experts
john h
Are you a Clymer Vacuum Expert? Answer questions, earn points and help others
